BYD Sealion 06 EV (2025-)Integrated Intelligent Rear Drive Domain System Circuit Diagram
This OEM circuit diagram is absolutely necessary if you troubleshooting and fixing the Sealion 06's Integrated Intelligent Rear Drive Domain System. Without this schematic breakout, you will not be able to trace whether the fault lies in the low voltage control supply, the interlock pins or network problems.
Common mistakes include replacing the expensive Integrate Rear Drive Domain module or a structural battery pack assembly while the root issue could be as simple as a loose interlock pin or an isolated grounding fault at point G101.
This OEM schematic will help you to map the proprietary architecture of BYD's unified domain control subnet. It will also help you to know the physical paths or pinouts of structural connectors like DB11(A)_3 or the specific grounding points needed to safely verify interlock loops
I have shared the link below on how to access this diagram and also a screenshot below for your verification. Feel free to ask any questions you may have in the chat below and I will be happy to answer.
