You can easily troubleshoot the door lock motors not working issue by simply referring to the OEM BYD Sealion 06 Wiring diagram. This diagram aids you in identifying the relevant control, power, and wiring paths.
Fixing the Sealion 06 door lock motors without the circuit information can result in incorrect wiring identification or incomplete circuit testing, which can lead to misdiagnosis and unnecessary replacement of door-lock motors or related components.
Common Questions This Wiring Diagram Can Help Answer
- Why are the BYD Sealion 06 EV door lock motors not working?
- How do you diagnose a BYD Sealion 06 EV door lock motor fault?
- How do you test the door lock motor circuit on a BYD Sealion 06 EV?
- How do you identify the wiring for the BYD Sealion 06 EV door lock motors?
- What should be checked before replacing a BYD Sealion 06 EV door lock motor?
- How does the BYD Sealion 06 EV door lock motor circuit relate to the front trunk lid and charging port lid lock systems?
How to Access the BYD Sealion 06 EV Wiring Diagram
To access the complete wiring diagram, simply click on the link below. I have also attached a screenshot that will guide you to quickly navigate to the right section. It is important to note that the year in the document is not the YOM but the document release date.- Access the Repair Database
