BYD Sealion 06 EV: Electric Rear Door Not Opening Diagnosis
The BYD Sealion 06 Wiring Diagram has crucial information needed for diagnosing and fixing the Electric Rear Door Not Opening fault. This OEM diagram provides a circuit-level reference needed to identify the system components and their electrical connections, helping you systematically trace the circuit when the powered rear door does not open.
Common Questions This Wiring Diagram Can Help Answer​
  1. Why is the BYD Sealion 06 EV electric rear door not opening?
  2. How do you diagnose the BYD Sealion 06 EV electric rear door system?
  3. How do you test the electric rear door switches and sensors?
  4. How do you test the electric rear door actuator circuit?
  5. How do you identify the power supply circuits for the BYD Sealion 06 EV electric rear door?
  6. Where is the controller circuit for the BYD Sealion 06 EV electric rear door?
  7. What wiring information is needed to diagnose an inoperative electric rear door?
How to Access the BYD Sealion 06 EV Wiring Diagram​
Click on the link below to access the complete Sealion 06 wiring diagram. We have also attached a screenshot that will guide you to quickly navigate to the right section. Also note that the year in the document is not the YOM but the document release date.
