BYD Sealion 06 EV: Gear Selector Not Engaging Drive Diagnosis (2025-Onwards)
If you are fixing the issue of the gear selector on your BYD Sealion 06 failing to engage drive, it is recommended to refer to the gear control and shift operation system circuit diagram, which is contained in the Wiring Diagram. This diagram provides the circuit-level reference needed to trace shift-control electrical connections.
I have shared the link below to access this Sealion 06 wiring diagram. I have also attached a screenshot below for you to verify.
