The CDCU VIN writing procedure on the XPENG G6 is very complicated without the correct OEM information. The XPENG G6 Repair Manual has detailed OEM reference information for Central Domain Controller VIN writing, which helps technicians locate the relevant information when CDCU VIN writing is required. Without the repair manual, the CDCU VIN-writing process can be performed incorrectly, leading to errors.
- How do you perform VIN writing for the CDCU on the XPENG G6?
- Where can I find the XPENG G6 CDCU VIN writing procedure?
- Which manual contains the XPENG G6 CDCU VIN writing instructions?
- Where can I find the XPENG G6 Central Domain Controller VIN writing procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the CDCU VIN Writing Procedure. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
