XPENG G6 Corner Radar Calibration Procedure
The XPENG G6 Corner Radar Calibration procedure provides the OEM information required to calibrate the vehicle’s corner radar sensors. This helps technicians complete corner radar calibration after component removal, replacement, or configuration.
Without the OEM Repair Manual, technicians may lack the source-confirmed calibration specifications required to correctly calibrate the Corner Millimeter-Wave Radar, which can result in calibration errors and unnecessary rework.
  • How do you calibrate the corner radar on the XPENG G6?
  • Where can I find the XPENG G6 corner radar calibration procedure?
  • How to perform corner radar calibration after replacement?
  • When is corner radar calibration required after component removal or replacement?
To access the XPENG G6 Repair Manual, click on the link below. I have attached a screenshot below to help you quickly navigate to the Corner Millimeter Wave Radar - Calibration. Once you find it, you can then print or save it.
