Replacing the power battery on the XPENG G6 can be very challenging without the OEM information. However, if you refer to the XPENG G6, it provides the relevant reference for completing power battery replacement and setup after component removal, replacement, or configuration.
- How to replace the power battery assembly on the XPENG G6?
- Where to find the XPENG G6 power battery replacement procedure?
- How to set up the power battery after replacement?
- What OEM information covers the XPENG G6 Power Battery Assembly replacement?
- What information is needed after removing or replacing the power battery assembly?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Power Battery Assembly - Replacement Process. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
