The XPENG G6 rear electric drive assembly removal and installation procedure is clearly defined in the repair manual. This manual provides an OEM reference for the rear electric drive system assembly, which helps technicians locate the relevant information when removing or installing the rear drive unit. Removing and installing the rear electric drive assembly can be very challenging without the repair manual.
- How to remove the XPENG G6 rear electric drive assembly?
- How to install the XPENG G6 rear electric drive assembly?
- Where can I find the XPENG G6 rear electric drive system assembly information?
- How do I remove the XPENG G6 rear drive unit?
- How do I install the XPENG G6 rear drive unit?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Electric Drive Assembly Removal and Installation Guide. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
