XPENG G6 Rear Electric Drive Lubricant Replacement
The process of draining and refilling the rear electric drive lubricant during scheduled or repair-related service is very important. Replacing the lubricant of the XPENG G6 rear electric drive without the OEM procedure may lead to improper servicing and more corrective work. The XPENG G6 repair manual provides technicians with a detailed process for replacing the lubricant correctly.
  • How to replace the rear electric drive lubricant on an XPENG G6?
  • What is the XPENG G6 rear electric drive lubricant replacement procedure?
  • How do you remove the lubricant from the XPENG G6 rear electric drive?
  • How do you refill the XPENG G6 rear electric drive lubricant?
  • What OEM procedure should you follow for rear electric drive lubricant replacement?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Electric Drive Lubricant Replacement Procedure. Once you find it, you can then print or save it.
