When replacing the rear motor oil cooler on the XPENG G6, it is recommended to always refer to the OEM repair manual. This document extensively covers the oil cooler assembly, providing technicians with information required to replace the rear motor oil cooler assembly. Without this information, technicians may lack the correct information needed to locate and replace the rear motor oil cooler. This risks improper installation, cooling-system issues, and unnecessary rework.
- How to replace the XPENG G6 rear motor oil cooler?
- Where can I find the XPENG G6 rear motor oil cooler replacement procedure?
- How do I remove and install the XPENG G6 rear motor oil cooler?
- Which OEM manual contains the XPENG G6 rear motor oil cooler replacement procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the oil cooler assembly. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
