XPENG technicians require the correct OEM information when replacing the wireless charging module on the XPENG G6. Without the correct information, they are likely to perform the replacement incorrectly, leading to configuration errors and unnecessary rework. The XPENG G6 Repair Manual provides the accurate replacement process, providing relevant reference for completing the wireless charging module.
- Where can I find the XPENG G6 wireless charging module replacement procedure?
- What OEM information covers the wireless charging module replacement?
- How do you replace the XPENG G6 Wireless Charging Module?
- Which manual contains the XPENG G6 wireless charging module replacement instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Wireless Charging Module Replacement Procedure. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
