BYD Sealion 06 EV: 12-Speaker Audio System Fault Diagnosis
When fixing the 12-speaker audio system fault for the BYD Sealion 06 EV, it is crucial to refer to the OEM Wiring diagram. This diagram includes a multimedia circuit diagram which will help you to identify the amplifier and speaker connections for the 12-speaker configuration when diagnosing a fault.
Without the circuit diagram, testing may be performed on the wrong audio-system configuration or wiring, making it harder to isolate the amplifier.
  • Why is the BYD Sealion 06 EV 12-speaker audio system not working?
  • How do you diagnose a BYD Sealion 06 EV 12-speaker audio-system fault?
  • How do you test the amplifier circuit on the BYD Sealion 06 EV 12-speaker system?
  • How do you test the speaker wiring on the BYD Sealion 06 EV?
  • How do you identify the correct amplifier and speaker wiring for the 12-speaker configuration?
  • Which multimedia circuit diagram applies to BYD Sealion 06 EV models with a 12-speaker amplifier?
  • How do you trace the audio-system wiring when the 12-speaker system is not working?
To access the wiring diagram, simply click on the link below. Within the diagram, you will find the brake-light circuit diagrams. I have attached a screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it.
