BYD Sealion 06 EV: 8-Speaker Audio System Fault Diagnosis
The BYD Sealion 06 Wiring Diagram is a must-have document when you are troubleshooting the audio system faults. Without the wiring diagram, fixing the audio system faults can be very challenging and time-consuming. However, if you have the diagram, it will help you to trace the amplifier, speaker, power and signal circuits applicable to BYD Sealion 06 EV models equipped with the 8-speaker amplifier.
  • Why is the BYD Sealion 06 EV 8-speaker audio system not working?
  • How do you diagnose a BYD Sealion 06 EV 8-speaker audio-system fault?
  • How do you test the amplifier circuit on the BYD Sealion 06 EV?
  • How do you test the speaker circuits on the BYD Sealion 06 EV?
  • How do you check the power supply to the 8-speaker amplifier?
  • How do you diagnose an audio signal circuit fault on a BYD Sealion 06 EV?
  • Which circuit diagram applies to BYD Sealion 06 EV models with an 8-speaker amplifier?
To access the wiring diagram, simply click on the link below. Within the diagram, you will find the multimedia circuit diagram. I have attached a screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it.
