BYD Sealion 06 EV: Driver Seat Heating Not Working Diagnosis
When repairing a BYD Sealion 06 EV driver’s seat heating system that is not working, it is important to refer to the OEM Wiring Diagram. The wiring diagram has circuit-level references that can help you trace the heating element, controller, switch, and wiring circuits involved.
  1. Why is the BYD Sealion 06 EV driver seat heating not working?
  2. How do you diagnose a BYD Sealion 06 EV driver seat heating fault?
  3. How do you test the driver seat heating element circuit?
  4. How do you test the driver seat heating switch?
  5. How do you diagnose the driver seat heating controller circuit?
  6. How do you identify the wiring for the BYD Sealion 06 EV driver seat heating system?
  7. What circuit diagram is needed to diagnose a BYD Sealion 06 EV driver seat heating fault?
To access the wiring diagram, simply click on the link below. Within the diagram, you will find the Driver Seat Ventilation and Heating System diagram. I have attached a screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it.
