The OEM Wiring diagram of the BYD Sealion 06 helps you to identify the front trunk lid lock system and distinguish between the lock motor, control circuitry, power supply, and wiring when diagnosing an inoperative lock.
Common Questions This Wiring Diagram Can Help Answer
- Why is the BYD Sealion 06 EV front trunk lid lock not working?
- How do you diagnose the BYD Sealion 06 EV front trunk lid lock circuit?
- How do you test the front trunk lid lock motor on a BYD Sealion 06 EV?
- How do you identify the wiring for the BYD Sealion 06 EV front trunk lid lock?
- How does the front trunk lid lock circuit connect to the door lock and charging port lid lock systems?
- What wiring information is needed to diagnose a BYD Sealion 06 EV front trunk lid lock fault?
How to Access the BYD Sealion 06 EV Wiring Diagram
To access the complete Sealion 06 wiring diagram, simply click on the link below. I have also attached a screenshot that will guide you to quickly navigate to the right section. Also, it is important to note that the year in the document is not the YOM but the document release date.- Access the Repair Database
