BYD Sealion 06 EV: Headlights and High Beams Fault Diagnosis
The OEM Wiring Diagram of the BYD Sealion 06 EV has crucial information needed when troubleshooting the headlights and high beams fault. Troubleshooting without the correct lighting circuit diagram can result in an incorrect circuit configuration and potentially lead to incorrect diagnosis or unnecessary component replacement.
Common Questions the BYD Sealion 06 Wiring Diagram Can Help Answer​
  1. Why are the BYD Sealion 06 EV headlights not working?
  2. Why are the BYD Sealion 06 EV high beams not working?
  3. How do you diagnose a BYD Sealion 06 EV headlight fault?
  4. How do you diagnose a BYD Sealion 06 EV high-beam fault?
  5. How do you identify the low-beam circuit on a BYD Sealion 06 EV?
  6. How do you identify the high-beam circuit on a BYD Sealion 06 EV?
  7. Which circuit diagram should be used to diagnose the BYD Sealion 06 EV headlights and high beams?
How to Access the BYD Sealion 06 EV Wiring Diagram​
To access the complete BYD Sealion 06 EV wiring diagram, click the link below. We have also attached a screenshot that will guide you to quickly navigate to the right section. Also note that the year in the document is not the YOM but the document release date.
