BYD Sealion 06 EV: Instrument Cluster Not Working Diagnosis
The BYD Sealion 06 Wiring Diagram has crucial information needed when fixing or diagnosing the instrument cluster faults. This wiring diagram will help you to identify and trace the relevant power, ground and network connections. Without the diagram, it is difficult to trace the circuits, and you may perform incorrect diagnosis do unnecessary component replacement.
  • Why is the BYD Sealion 06 EV instrument cluster not working?
  • How to diagnose a BYD Sealion 06 EV instrument cluster fault?
  • How to test the power supply to the BYD Sealion 06 EV instrument cluster?
  • How to check the instrument cluster ground circuit?
  • How to diagnose the network circuit connected to the BYD Sealion 06 EV instrument cluster?
  • What circuit diagram is needed to diagnose a BYD Sealion 06 EV instrument cluster fault?
  • How to trace the instrument cluster circuit when the cluster is not working?
To access the wiring diagram, click on the link below. Within the diagram, you will find the instrument cluster circuit diagram. I have attached a screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it.
