BYD Sealion 06 EV: Intermittent Grounding Fault Diagnosis
You can easily repair the BYD Sealion 06's intermittent grounding fault by referring to the OEM wiring diagram. The wiring diagram helps you to identify the ground paths and locate applicable grounding points during intermittent fault diagnosis.
Attempting to perform repairs without this diagram can be costly, as you are likely to do incorrect tests, misdiagnose, and spend many hours trying to find the correct circuits.
Click the link below to access the complete BYD Sealion 06 wiring diagram. I have also attached a screenshot that will guide you to quickly navigate to the right section.
