BYD Sealion 06 EV: Multi-Color Ambient Lighting Fault Diagnosis (2025 Onwards)
Diagnosing and fixing the multi-colour ambient lighting fault can easily be done by referring to the OEM BYD Sealion 06 EV wiring diagram. This diagram contains the circuitry-level reference to identify the relevant ambient-lighting circuits you need and trace the system's control, communication, and lighting connections.
Common Questions the BYD Sealion 06 Wiring Diagram Can Help Answer​
  1. Why is the BYD Sealion 06 EV multi-color ambient lighting not working?
  2. How do you diagnose a BYD Sealion 06 EV ambient lighting fault?
  3. How do you test the multi-color ambient lighting circuit?
  4. How do you diagnose a communication fault in the ambient lighting system?
  5. How do you identify the control circuit for the BYD Sealion 06 EV multi-color ambient lighting?
  6. What wiring information is needed to diagnose a BYD Sealion 06 EV ambient lighting fault?
How to Access the BYD Sealion 06 EV Wiring Diagram​
To access the complete BYD Sealion 06 EV wiring diagram, click the link below. We have also attached a screenshot that will guide you to quickly navigate to the right section. Also note that the year in the document is not the YOM but the document release date.
