BYD Sealion 06 EV: Panoramic Sky Dome Not Working Diagnosis
The panoramic sky dome not working issue can be challenging to fix if you don't have the BYD Sealion 06 EV OEM Wiring Diagram. The wiring diagram helps you to identify the system's relevant electrical circuits and trace the connections between the switch, control system, motor and power supply when diagnosing an inoperative roof.
Common Questions the BYD Sealion 06 Wiring Diagram Can Help Answer​
  1. Why is the BYD Sealion 06 EV panoramic sky dome not working?
  2. How do you diagnose a BYD Sealion 06 EV panoramic sky dome fault?
  3. How do you test the panoramic sky dome motor circuit?
  4. How do you test the panoramic sky dome switch circuit?
  5. How do you identify the power supply circuit for the BYD Sealion 06 EV panoramic sky dome?
  6. What wiring information is needed to diagnose a panoramic sky dome that is not working?
  7. How do you distinguish a panoramic sky dome motor fault from a control or supply-circuit fault?
How to Access the BYD Sealion 06 EV Wiring Diagram​
Click the link below to access the complete Sealion 06 wiring diagram. We have also attached a screenshot that will guide you to quickly navigate to the right section. Also note that the year in the document is not the YOM but the document release date.
