The power window not working fault can easily be fixed by referring to the OEM BYD Sealion 06 EV wiring diagram. This digram helps you to identify and trace the relevant windshield lifting system circuits, helping distinguish between motor, switch, supply and control-related faults. Without the wiring diagram, you are likely to spend hours trying to fix the fault, and you might do incorrect tests or potentially do unnecessary parts replacement.
Click the link below to access the wiring diagram. We have also attached a screenshot that will guide you to quickly navigate to the right section. Also note that the year in the document is not the YOM but the document release date.
Common Questions the BYD Sealion 06 Wiring Diagram Can Help Answer
- Why is the BYD Sealion 06 EV power window not working?
- How do you diagnose a BYD Sealion 06 EV power window fault?
- How do you test the power window motor circuit?
- How do you test the power window switch circuit?
- How do you identify the power supply circuit for the BYD Sealion 06 EV window system?
- How do you diagnose a power window control-circuit fault?
- What wiring information is needed to diagnose a BYD Sealion 06 EV power window that is not working?
How to Access the BYD Sealion 06 EV Wiring Diagram
