BYD Sealion 06 EV: Rear Windshield Heating Fault Diagnosis
When diagnosing the rear windshield heating fault on the BYD Sealion 06 EV, it's crucial to always refer to the OEM Wiring Diagram. This diagram helps you trace the rear windshield heating circuit and identify the relevant heater grid and power connections. Without the circuit diagrams, it can be difficult to correctly identify the rear windshield power circuits.
  1. Why is the BYD Sealion 06 EV rear windshield heating not working?
  2. How to diagnose a BYD Sealion 06 EV rear windshield heating fault?
  3. How to test the rear windshield heater circuit?
  4. How to check the power supply to the BYD Sealion 06 EV rear windshield heating system?
  5. How to diagnose a rear windshield heater grid fault?
  6. How to identify the wiring for the BYD Sealion 06 EV rear windshield heating system?
  7. Which circuit diagram is needed to diagnose a BYD Sealion 06 EV rear windshield heating fault?
To access the wiring diagram, simply click on the link below. Within the diagram, you will find the windshield heating circuit diagram. I have attached a screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it.
