BYD Sealion 06 EV: Wireless Phone Charger Fault Diagnosis
The Wiring Diagram is required when you are troubleshooting the wireless phone charger fault on the BYD Sealion 06 EV. It helps you to identify and trace the dedicated power and control circuits associated with the wireless phone charging system. Without the wiring diagram, it may be difficult to correctly identify the USB Charging, Backup Power Supply, and Wireless Phone Charging System Circuit Diagrams.
  1. Why is the BYD Sealion 06 EV wireless phone charger not working?
  2. How do you diagnose a BYD Sealion 06 EV wireless phone charger fault?
  3. How do you test the wireless phone charger power circuit?
  4. How do you test the wireless phone charger control circuit?
  5. How do you identify the wiring for the BYD Sealion 06 EV wireless phone charger?
  6. Which circuit diagram is needed to diagnose the BYD Sealion 06 EV wireless phone charger?
  7. How does the wireless phone charging system connect with the backup power supply and USB charging circuits?
To access the wiring diagram, simply click on the link below. Within the diagram, you will find the USB Charging, Backup Power Supply, and Wireless Phone Charging System Circuit Diagrams. I have attached a screenshot below to help you quickly navigate to the section where the diagram is located. Once you find it, you can then print or save it.
USB Charging, Backup Power Supply, and Wireless Phone Charging System Circuit Diagrams.jpg
