BYD SEALION 6 DM-i Adjustment of Front Door Assembly
The Front door assembly of the BYD Sealion 6 DM-i is complex and requires technicians to have the factory documentation when making adjustments during repairs. This OEM documentation provides exact panel gap and flushness measurements, hinge mounting bolt torque settings, striker alignment protocols, and weatherstrip seal contact checks. Attempting to adjust the front door assembly without the OEM procedures may cause the door to sag, uneven panel gaps, severe high-speed wind noise, or water leaks.
The BYD Sealion 6 DM-i Repair Manual Helps Answer These Questions
  • How to adjust the front door alignment and fix door sag on a BYD SEALION 6 DM-i?
  • What are the factory panel gap specifications for the front door on a BYD SEALION 6 DM-i?
  • How to adjust the front door striker plate to fix hard closing or wind noise on a BYD SEALION 6 DM-i?
  • What are the torque values for the front door hinge bolts on a BYD SEALION 6 DM-i?
  • How to eliminate water leaks around the front door seal on a BYD SEALION 6 DM-i?
How to Access the BYD Sealion 6 DM-i Repair Manual
To access the BYD repair manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to Adjustment of Front Door Assembly. Once you find it, you can then print or save it.
