BYD SEALION 6 DM-i Adjustment of Rear Door Assembly
When doing adjustments to the BYD Sealioj 6 DM-i's rear door, it is important to have the OEM repair information. Having this factory documentation enables technicians to get the exact upper and lower pillar hinge adjustment steps, door latch striker plate positioning, body line alignment procedures, and weatherstrip seal compression checks. Attempting to adjust the Sealion 6 DM-i's rear door assembly without the correct specifications may cause the door to sag, misaligned body character lines, paint rubbing, and persistent wind noise or water intrusion into the rear passenger cabin.
The BYD Sealion 6 DM-i Repair Manual Helps Answer These Questions
  • How to adjust the rear door alignment and eliminate door sag on a BYD SEALION 6 DM-i?
  • What are the factory panel gap tolerances between the front and rear doors on a BYD SEALION 6 DM-i?
  • How to adjust the rear door striker plate to fix sticking or hard-closing doors on a BYD SEALION 6 DM-i?
  • What are the torque settings for the rear door hinge bolts on a BYD SEALION 6 DM-i?
  • How to fix water leaks or wind noise around the rear door frame on a BYD SEALION 6 DM-i?
How to Access the BYD Sealion 6 DM-i Repair Manual
To access the BYD repair manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to Adjustment of Rear Door Assembly. Once you find it, you can then print or save it.
