BYD SEALION 6 DM-i Adjustment of the Front Bumper Lock
Adjusting the front bumper lock on the BYD Sealion 6 DM-i requires technicians to have the correct factory documentation. With this documentation, technicians have step-by-step instructions for release cable tension setting, lock body height and lateral position alignment, mounting bolt torque values, and functional verification of primary latching, safety catch retention, and interior release handle travel. Attempting to adjust the front bumper lock without following the correct procedure risks causing failure of the hood primary latch to engage securely.
The BYD Sealion 6 DM-i Repair Manual Helps Answer These Questions
  • How to align and adjust the front hood latch/bumper lock mechanism on a BYD SEALION 6 DM-i?
  • What are the torque specifications for the front hood latch mounting bolts on a BYD SEALION 6 DM-i?
  • How to adjust the front hood release cable tension on a BYD SEALION 6 DM-i?
  • What causes the front hood release handle to feel stiff or fail to pop the hood open on a BYD SEALION 6 DM-i?
  • How to ensure the front hood safety catch is fully engaging after bumper or latch repairs on a BYD SEALION 6 DM-i?
How to Access the BYD Sealion 6 DM-i Repair Manual
To access the BYD repair manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to Adjustment of the Front Bumper Lock. Once you find it, you can then print or save it.
