Technicians and workshops are required to refer to the Official OEM service procedures when adjusting the front hood of the BYD SEALION 6 DM-i. This factory documentation provides exact panel gap and flushness specs, hinge bolt torque settings, rubber buffer height adjustment steps, and latch striker centering techniques, ensuring clean panel alignment. Trying to adjust the hood without the correct procedures risks uneven panel gaps, wind noise, or severe water ingress into the engine compartment.
The BYD Sealion 6 DM-i Repair Manual Helps Answer These Questions
To access the BYD repair manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to Adjustment of the Front Hood. Once you find it, you can then print or save it.
- How to adjust the front hood alignment and panel gaps on a BYD SEALION 6 DM-i?
- What are the factory panel gap specifications between the hood, fender, and bumper on a BYD SEALION 6 DM-i?
- How to adjust the height of the hood rubber stops on a BYD SEALION 6 DM-i to eliminate vibration?
- How to center and adjust the front hood latch striker for smooth closing on a BYD SEALION 6 DM-i?
- What causes the front hood to sit unevenly or catch on the headlights during closure on a BYD SEALION 6 DM-i?
