When replacing the mechanical steering gear rack and inner/outer tie rod assembly on the BYD SEALION 6 DM-i, technicians must have the correct OEM reference. Without the factory documentation, technicians and workshops risk unbalancing the front subframe, damaging power steering harness connections, or ruining tie rod boot seals during ball joint extraction. Having the official BYD SEALION 6 DM-i service documentation gives technicians the physical rack removal sequences, subframe clearance protocols, ball joint separator usage guidelines, exact fastener torque-plus-angle specifications, and wheel alignment and EPS diagnostic calibration procedures.
The BYD Sealion 6 DM-i Repair Manual Helps Answer These Questions
To access the BYD repair manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to Disassembly and Assembly of Mechanical Steering Gear with Tie Rod Assembly. Once you find it, you can then print or save it.
- How to remove and replace the mechanical steering rack and tie rod assembly on a BYD SEALION 6 DM-i?
- What are the mounting bolt torque specifications for the steering gear rack on a BYD SEALION 6 DM-i?
- Do I need to lower the front subframe to remove the steering rack on a BYD SEALION 6 DM-i?
- How to disconnect the tie rod end ball joints without damaging the rubber boots on a BYD SEALION 6 DM-i?
- What calibrations and adjustments must be performed after replacing the steering gear assembly on a BYD SEALION 6 DM-i?
