The XPENG G6 Repair Manual clearly defines the process of replacing the airbag ECU of the G6. Without the relevant information, technicians may lack the source-confirmed replacement information required for the airbag ECU replacing, which may result in configuration errors and unnecessary rework.
- How do you replace the airbag ECU on the XPENG G6?
- What OEM information covers the airbag ECU replacement?
- How do you replace the XPENG G6 airbag ECU?
- What information is needed after removing or replacing the airbag ECU?
- Where can I find the XPENG G6 Airbag ECU replacement process?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Airbag Ecu Replacement Procedure. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
