If you are replacing the battery lower guard plate, it is important to use the correct procedure, which is entailed in the XPENG G6 Repair Manual. Without this information, the battery lower guard plate replacement process can be performed incorrectly, risking inadequate protection and unnecessary rework.
- How to replace the XPENG G6 battery lower guard plate?
- Where can I find the XPENG G6 battery lower guard plate information?
- Where can I find the XPENG G6 battery lower guard plate removal and installation information?
- Which OEM manual contains the XPENG G6 battery lower guard plate replacement information?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Battery Lower Guard Plate Replacement. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
