XPENG G6 Bluetooth Uwb Submodule Replacement Procedure
The Bluetooth UWB Submodule Replacement procedure is clearly defined in the Repair Manual of the XPENG G6. Trying to replace the UWB submodule without the correct information can be quite difficult, and you are likely to make configuration errors and unnecessary rework. The XPENG Repair Manual provides the complete process required for configuration after replacement.
  1. How do you replace the Bluetooth UWB submodule on the XPENG G6?
  2. Where can I find the XPENG G6 Bluetooth UWB submodule replacement procedure?
  3. What OEM information covers the Bluetooth UWB Submodule replacement?
  4. How do you replace the XPENG G6 Bluetooth UWB Submodule?
  5. Which manual contains the XPENG G6 Bluetooth UWB submodule replacement instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Bluetooth UWB Submodule Replacement Instructions. Once you find it, you can then print or save it.
