XPENG G6 C003808 / C00A400 / C00A500: Left Rear Wheel Speed Sensor Fault
The XPENG G6 repair manual provides a step by step procedure for interpreting the left rear wheel sensor fault codes and therefore enabling technicians apply diagnostic and repair processes for the faults identified. Without the XPENG G6 repair manual technicians may interprete the fault codes incorrectly resulting in an incomplete diagnostic process and unnecessary component replacement.
  • What does XPENG G6 fault codes C003808, C00A400 and C00A500 indicate?
  • How do i diagnose the XPENG G6 left rear wheel speed sensor fault?
  • How do i troubleshoot C003808 on an XPENG G6?
  • How to diagnose C00A400 and C00A500 on an XPENG G6?
  • What is the OEM diagnostic procedure for the XPENG G6 left rear wheel speed sensor fault?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the C003808 / C00A400 / C00A500: Left Rear Wheel Speed Sensor Fault. Once you find it, you can then print or save it.
