Right rear wheel speed sensor fault disables critical active safety systems, technicians need the correct OEM diagnostic information contained in the XPENG G6 repair manual for intepreting the sensor fault codes and determining which procedure to be used to fix the problem. Without the XPENG G6 repair manual technicians risk interpreting the fault codes incorrectly leading to incomplete diagnostic processes and costly unnecessary component replacement.
The XPENG G6 Repair Manual helps answer these questions.
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the C003B08 / C051400 / C051500: Right Rear Wheel Speed Sensor Fault. Once you find it, you can then print or save it.
- What do XPENG G6 fault codes C003B08, C051400 and C051500 indicate?
- How do I diagnose the XPENG G6 right rear wheel speed sensor fault?
- How do I troubleshoot C003B08, C051400 and C051500 on an XPENG G6?
- What is the OEM diagnostic procedure for the XPENG G6 right rear wheel speed sensor fault?
- What should I check when C003B08, C051400, or C051500 is present?
