AVH switch failure diagnosis is challenging for technicians without the OEM information. XPENG G6 repair manual contains information for interpreting the fault code C104D04 and appropriate troubleshooting procedure for the repair. Without the OEM information C104D04 will be interpreted incorrectly causing damage to the XPENG G6.
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the AVH Switch Failure. Once you find it, you can then print or save it.
- What does XPENG G6 fault code C104D04 mean?
- How do I diagnose the XPENG G6 AVH switch failure?
- How do I troubleshoot C104D04 on an XPENG G6?
- What is the OEM diagnostic procedure for XPENG G6 C104D04?
