Updating the software of the XPENG G6 electronic control modules can be a bit challenging without the OEM reference information. The XPENG G6 Repair Manual provides the relevant reference for performing a control module software update after diagnosis or replacement. Without the Repair Manual, technicians are likely to lack source-confirmed information needed to perform the software upgrade.
- How do you perform a software upgrade on the XPENG G6?
- Where can I find the XPENG G6 control module software upgrade procedure?
- How to update control module software on the XPENG G6?
- When is a software upgrade required after control module replacement?
- Which manual contains the XPENG G6 software upgrade instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Software Upgrade information. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
