The XPENG G6 Repair Manual provides the OEM information required to drain, refill, and replace the coolant on the XPENG G6. This information is crucial for technicians to locate the relevant information when servicing the vehicle cooling circuits. Draining and replacing the coolant on the XPENG G6 without the repair manual can be performed incorrectly, increasing the risk of improper servicing.
- How to drain coolant on the XPENG G6?
- How to refill coolant on the XPENG G6?
- What does the XPENG G6 coolant replacement procedure cover?
- Where can I find the XPENG G6 coolant drainage procedure?
- Where can I find the XPENG G6 coolant refilling procedure?
- When is coolant replacement required on the XPENG G6?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the coolant drain, refill, and replacement. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
