The electric compressor replacement procedure is quite complicated without the correct OEM information. We recommend technicians refer to the repair manual, which provides step by step for for completing electric compressor replacement after component removal, replacement, or configuration.
- How do you replace the electric compressor on the XPENG G6?
- Where can I find the XPENG G6 electric compressor replacement procedure?
- What OEM information covers the electric compressor replacement?
- Which manual contains the XPENG G6 electric compressor replacement instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Electric Compressor Replacement Instructions. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
