Inspecting and fixing the high-voltage insulation on the XPENG G6 is very challenging without accurate OEM service information. The XPENG G6 Repair Manual provides reference information for high-voltage component insulation inspection helping you to locate the relevant information.
- How do you inspect high-voltage component insulation on the XPENG G6?
- Where can I find the XPENG G6 high-voltage insulation inspection procedure?
- How do you check high-voltage component insulation after a fault?
- How to inspect XPENG G6 high-voltage component insulation after repair?
- What information is needed to inspect the insulation of XPENG G6 high-voltage components?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to thehigh-voltage components. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
