XPENG G6 Imu Calibration Procedure
The XPENG G6 repair manual provides technicians with the Imu calibration guide which is important after a component has been replaced, removed or configured. Proceeding without the OEM information will lead to incomplete or unsuccessful calibration process.
  • What OEM procedure should you follow for XPENG G6 IMU calibration?
  • What are the instructions for XPENG G6 IMU calibration?
  • When is IMU calibration required on the XPENG G6?
  • How do you complete IMU calibration after component replacement?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Imu Calibration Procedure. Once you find it, you can then print or save it.
