XPENG G6 Inverter Core Replacement
If you are replacing the inverter core on the XPENG G6, it is very crucial to rely only on the correct OEM information. The XPENG G6 Repair Manual provides OEM reference for the inverter core assembly. This information aids technicians in locating the relevant information when removing and installing the inverter core. Replacing the invetor core without the repair manual can lead to improper installation, electrical faults, and unnecessary rework.
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Battery Lower Guard Plate Replacement. Once you find it, you can then print or save it.
