XPENG G6 Nfc Key Learning Procedure
This learning procedure is a required technical operation which is impotant to technicians after a related work component removal, replacement or configuration. Key learning may be prevented from bieng completed correctly if the OEM learning procedure is not used.
  • How do I perform the XPENG G6 NFC key learning procedure?
  • What are the instructions for XPENG G6 NFC key learning?
  • When is NFC key learning required on the XPENG G6?
  • How do I complete NFC key learning after component replacement?
  • What OEM procedure should I follow for XPENG G6 NFC key learning?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Nfc Key Learning Procedure. Once you find it, you can then print or save it.
