Replacing the OBC/DC-DC on the XPENG G6 is very complicated without the repair manual. This manual provides the correct procedure for completing the OBC/DC-DC replacement after component removal, replacement, or configuration. Without this document, technicians may lack the source-confirmed replacement information required for the Charger/DC Converter.
- Where can I find the XPENG G6 OBC/DC-DC replacement procedure?
- What OEM information covers the charger/DC converter replacement?
- How do you replace the XPENG G6 Charger/DC Converter?
- Which manual contains the XPENG G6 OBC/DC-DC replacement instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Charger/DC Converter - Replacement Process. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
