The XPENG G6 Repair Manual provides the correct procedure to carry out the power battery cooling circuit test on the G6. This information helps technicians locate the relevant information when pressure-testing the battery cooling circuit. Without the XPENG G6 Repair Manual, the power battery cooling system air tightness test can be performed incorrectly, causing leaks or improper battery cooling system servicing.
- How to perform the XPENG G6 power battery cooling-circuit airtightness test?
- Where can I find the XPENG G6 power battery cooling-circuit testing procedure?
- How do I pressure-test the XPENG G6 battery cooling circuit?
- Which OEM manual contains the XPENG G6 power battery cooling-circuit airtightness test procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Power Battery Cooling-Circuit Airtightness Test. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
