XPENG G6 Power Battery Damage Inspection
Inspecting the power battery damage on the XPENG G6 can be challenging for technicians without the correct OEM information. This information is contained in the XENG G6 Repair Manual. The manual has the source-confirmed reference information for inspecting the battery after impact or underbody damage. Without OEM information, the damage can be incorrectly assessed.
  • How to inspect the XPENG G6 power battery for damage?
  • Where can I find the XPENG G6 power battery damage inspection procedure?
  • When should the XPENG G6 power battery be inspected for damage?
  • Which OEM manual contains the XPENG G6 power battery damage inspection information?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Power Battery Damage Inspection. Once you find it, you can then print or save it.
