When testing the power battery's internal-cavity airtightness on the XPENG G6, it is necessary to refer to the OEM Repair Manual. The manual provides source-confirmed reference information for checking pack sealing after repair. Performing tests, without the repair manual, technicians may lack the correct information needed to locate and follow the power battery assembly internal-cavity airtightness testing procedure when checking pack sealing after repair.
- How to perform the XPENG G6 power battery internal-cavity airtightness test?
- Where can I find the XPENG G6 power battery airtightness testing procedure?
- When should the XPENG G6 power battery airtightness be tested?
- Which OEM manual contains the XPENG G6 power battery internal-cavity airtightness test procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Power Battery Internal-Cavity Airtightness Test. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
