XPENG G6 Power Battery Removal and Installation
The power battery removal and installation process is clearly defined in the XPENG G6 Repair Manual. This factory manual gives you the reference covering power battery assembly disassembly and installation, which helps XPENG technicians locate the relevant information when removing or installing the traction battery.
Removing and installing a power battery without the OEM information can be risky, as it can result in damage to the battery casing, connectors, terminals, or internal components.
  • How to remove the XPENG G6 power battery?
  • How to install the XPENG G6 power battery?
  • Where can I find the XPENG G6 power battery removal procedure?
  • What information covers XPENG G6 power battery installation?
  • Where can I find the XPENG G6 traction battery removal and installation information?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Power Battery Removal and Installation Guide. Once you find it, you can then print or save it.
