When replacing or inspecting the rear brake pad on the XPENG G6, it is crucial to use the OEM reference contained in the Xpeng G6 Repair Manual. This manual gives technicians the information required to correctly remove, replace, and inspect the rear disc brake friction pads. Without this manual, the inspection and replacement process can be performed incorrectly, resulting in improper brake servicing.
- How to replace the rear brake pads on the XPENG G6?
- How to inspect the XPENG G6 rear brake pads?
- Where can I find the XPENG G6 rear disc brake friction pad information?
- What information covers rear brake pad inspection on the XPENG G6?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Brake Pad Replacement and Inspection. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
