XPENG G6 Rear Drive Cooling-Circuit Airtightness Test
The XPENG G6 repair manual provides the OEM reference needed when testing the rear drive cooling-circuit airtightness. This manual provides the source-confirmed reference information relevant to pressure-testing the drive-unit cooling circuit. Performing tests without the repair manual information can result in the test being done incorrectly or leaks being missed.
  • How to perform the XPENG G6 rear drive cooling-circuit airtightness test?
  • Where can I find the XPENG G6 rear drive cooling-circuit testing procedure?
  • What OEM information covers the rear electric drive system cooling circuit airtightness test?
  • How do I pressure-test the XPENG G6 rear drive cooling circuit?
  • Which OEM manual contains the XPENG G6 rear drive cooling-circuit airtightness test procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Drive Cooling-Circuit Airtightness Test. Once you find it, you can then print or save it.
