XPENG G6 Rear Drive Enclosure Airtightness Test
When testing the rear drive enclosure airtightness, it is crucial to have the correct OEM information. The XPENG G6 Repair Manual provides this information, which is needed by technicians to locate the relevant information when checking rear drive enclosure sealing. Performing the airtightness test without the repair manual can result in the test being performed incorrectly or sealing issues being missed.
  • How to perform the XPENG G6 rear drive enclosure airtightness test?
  • Where can I find the XPENG G6 rear drive enclosure airtightness testing procedure?
  • When should the XPENG G6 rear drive enclosure airtightness be tested?
  • Which OEM manual contains the XPENG G6 rear drive enclosure airtightness test procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Interior of Rear Electric Drive System Enclosure—Airtightness Testing. Once you find it, you can then print or save it.
