When replacing the rear drive output oil seal on the XPENG G6, it is important to rely on the correct OEM information. The XPENG G6 Repair Manual provides the OEM reference information needed to repair a drive-unit output seal leak. Without this information, the output oil seal replacement process may be performed incorrectly, increasing the risk of an unresolved leak.
- How to replace the XPENG G6 rear drive output oil seal?
- Where can I find the XPENG G6 rear drive output oil seal replacement procedure?
- How can I repair a rear drive output seal leak on the XPENG G6?
- Which OEM manual contains the XPENG G6 rear drive output oil seal replacement procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Output Oil Seal. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
